Random plumbing pics
They backfilled to bury the top of the septic tank so only the risers stick up. The deeper they dug on that project the whiter the sand got and the harder it was for it to not collapse inward.
It looked lighter in person than in photos
This was when they were partially done.
As an aside, I was watching a Perkins Builder Brothers episode on Youtube and they brought in a black plastic septic tank that looked too small for the size of the house and it looked like they were using Infiltrator Systems segments for the field lines.
Friend is renovating the bathroom of people across the street. They have been having health issues and he found out they didn't have a working bathroom so he's been helping them out. He did drywall today.
And vinyl tile
This is the vanity that will go in. Obviously the top is not on correctly yet.
When my air handler was removed I was able to take photos inside the air circulation compartment. Still have the old PVC and CPVC going up to the water heater. The corroded copper under is the refrigerant line. I don't think it is leaking from there since it would most likely leak at a joint and nothing has gone in there to damage the pipe.
Does new stuff for HVAC in terms of pipe layout count as plumbing? LOL.
This shows where the condensate line goes underneath. Looks like there are some mini studs in the way of where I want to put the new grille. So either we need to keep the location in my brother's room or need to move some studs a little. There's support directly under the water heater so hopefully that won't be a problem.
I need to vacuum inside that compartment.
LOL, Jeff, that was the very first thing I noticed and I was like "Well, the top hasn't been installed yet" and friend said it's actually upsidedown. Friend said the vinyl flooring is very thick. Said he's going to use my toilet jack to move the toilet and finish the flooring where the toilet goes.
I'll have to dig up earlier pics but that bathroom was dark, dingy, moldy, and gross before my friend fixed it up. The guy had a heart attack or something and they had not had a working bathroom for a year and the wife was super stressed all the time. Their marriage has improved and both are much happier with my friend helping them. He's a good dude. Sadly, they don't know me so I don't get to go paint. LOL.
Was washing dishes and heard water pouring under the sink.
I'd had the doors jammed shut with stuff in front to keep cats out because the old hinges don't keep the doors shut properly.
Saw this:
This held for almost 10yrs after I did it-- still need to modify it to add a vent and go to sch40 pvc going through the floor. Top nut would turn on the elbow but the bottom one to let me bring the pipe up was stuck. Even my brother couldn't get it. Friend went and grabbed a $5 oil filter wrench, came out and fixed it in a couple minutes. It took longer for him to put the knee pads on than to get the pipes moved and together. Not sure why it shifted like that. Apparently it's been leaking for awhile bc the bottom of the cabinet is collapsing. I'm going to have to replace it but I think I have a chunk of plywood in the hallway that can be used.
No pics after it was fixed. I need to deep clean under there.
The pvc water supply line is not connected to anything. The pipes for it under the house ruptured a few years back.
