berderder
Hi ya'll,
While trying to install a filtered water spout, I opened up pandora's box with corroded fittings on my water supply lines. Even after removing as much gunk as possible from copper (or is it brass?) elbow and hand tightening new MIP nipple with clockwise teflon tape, I'm still getting a little leak. At this point I'm afraid of replacing the elbow and yanking on the supply coming through the floor because the thing seems really stuck.
House was built in 1918 and so this plumbing work maybe is from 1960's to 1990's? Should I close up the hole around the base of the water supply? That's let water leak down into the basement where I have a blower fan on high pointing at that spot.
Also, what do you think I should do about this jumble of ductwork, dryer vent, sewer, etc down here if anything? Does anything stand out to you? Seems like something could be better routed or organized
