Just a wild guess that the metal trap went bad, and this was hopefully some wacky temporary solution until that trap assembly was replaced!I like that sink drain going into the toilet. I'll have to remember that one.
What? Dangling wires and the open pressure switch box???Looks like electrical code violations are here as well.
Necessity is the mother of invention and I do miss Frank Zappa's crappa!Just a wild guess that the metal trap went bad, and this was hopefully some wacky temporary solution until that trap assembly was replaced!
Miracle Worker!So, my mother can't bend to clean without falling over & my brother has never cleaned a toilet in his life and refuses to do so. Mom asked me to put water in Fippy's bowl in the bathroom & I saw the toilet. I haven't used it in months & it was so gross I knew I had to do something (I clean my own toilet regularly-- although it doesn't get that dirty unless my brother uses it). The seat has rust stains from the hard water & its a closed cell foam so the stains won't come out.
This is the before:
So, I got the clorox toilet wand, the clorox cleaner, some kind of cleaner I found in a bucket (can't remember what it was called-- fabuloso?) clorox wipes, a rubbermaid electric scrubber (looks like a toothbrush), etc.. Batteries were about dead in the rubbermaid so I went to change the batteries and one fell down the sink drain (bc my brother keeps taking the stopper out). Had to fish it out with a magnet stick. Spent an hour scrubbing the thing (and the squatty potty thing below). I had to sit on that nasty floor bc my back started giving me grief. I discovered that if you are wiping downward on the bidet sprayer it can make it come down and spray-- got hit in the face twice. LOL.
But, this is the final result:
Some of that crud won't come off no matter how much I scrubbed. Floor needs to be repaired and trash needs to be picked up, but last time I picked up trash I got yelled at bc Mom wanted to keep some of the trash. She fell asleep while I was cleaning so I couldn't ask her about it. I really like the Clorox wand thingy (although I wish it was longer so I wouldn't have to bend as much) because it doesn't have bristles that fling crud into my face and it seems to clean better than regular toilet brushes.
I'm amazed you cleaned all that with an amazon prime bagSo, my mother can't bend to clean without falling over & my brother has never cleaned a toilet in his life and refuses to do so. Mom asked me to put water in Fippy's bowl in the bathroom & I saw the toilet. I haven't used it in months & it was so gross I knew I had to do something (I clean my own toilet regularly-- although it doesn't get that dirty unless my brother uses it). The seat has rust stains from the hard water & its a closed cell foam so the stains won't come out.
This is the before:
Maybe by beating it into submission?Zanne how did that pipe wrench come in to cleaning the tub. LOL.......
You know the fire got hot enough if the wrench meltsZanne how did that pipe wrench come in to cleaning the tub. LOL.......
Friend used it to remove the tub spout that was stuck on. It was installed with so much silicone that we couldn't reach to cut (it was on the inside of the tub spout around the pipe) and that sucker would not turn. I tried the whole screwdriver in the opening and turning thing, but metal broke off the mouth of it. Tried various size wrenches and friend decided that one would do the job.Zanne how did that pipe wrench come in to cleaning the tub. LOL.......
I always keep a 4ft pipe wrench on hand just in case.... You never know when someone needs to be set straight...I do have a 4 ft rigid steel pipe wrench. Used it on a boiler pipe once. Darn thing is heavy.
