replace leaking galvanized pipe section with what?
jbclem
Jul 7, 2022
10
Palookaville, Calif.
My main water line(3/4" galvanized) is leaking at a spot near the water meter. If I replace the 10 foot section that's leaking, is there something better than galvanized I can replace it with, or do I have to use the same galvanized? It's about 12" underground.
Steel pipe is obsolete for water piping. Rusts out readily with age.
While I certainly wouldn't use that material for new construction, the old stuff has held up quite well in our part of Southern California. The pipes in our house were installed in the late 1950's and the couple of pieces I have been able to see (one pipe cut to replace a valve, the ends of the pipes to the sprinkler valves) are rusted, but only a thin layer. No sign of the "packed with rust" that everybody talks about. I'm guessing that the lack of aeration (usually) combined with the hard water is somehow protective. That said, the main line we replaced, which was of course buried in dirt, was pretty nasty looking on the outside. It was not, however, leaking. It was replaced because the valve at one end was stuck open and the one at the other end, next to the city's shut off was dripping out of its handle. We put thick copper in to replace the galvanized there. When we do the house that will be PEX.
