Two...
Guessing you changed the mower from gas to propane because.... you could.
You find any advantage to burning propane?
Bravo Sir! Thank you for sharing. Hopefully this trick with the heater box will help me someday
The 1lb throw away bottles are not transportable in a vehicle after refilling.Nice hack. We're tired of the maintenance and failures associated with current gas fuels. If you forget about a portable generator one winter, you will have a regrettable cost experience. There are some RV places that won't refill the small containers, partly depends on the container, but we have a propane tank. Would be interested in any details you would be willing to share, but understand if you don't want to do that.
The carburetor gets sealed up. All the holes get epoxy.,Curious about what changes you had to make to the carburetor. I see the regulator below the handle. Is that all you use to adjust the fuel rate?
And is that a 2 lb or 4 lb bottle on your mower?
Don’t do drugs kids.....
You wanna hear the story ?We don't need no stinking meter!?!
