Chris
OK so I just bought a home in the mountains that is on a water tank and septic holding tank. No well. Filled the tank and everything works great. I was told I have an issue but want to make sure. To me everything works like an RV but better, when you turn on water after a second the pump will kick on (Pump is located under my stairs between floors so you can slightly here it). Now when you take a shower it will kick on for a second or two then kick off and will repeat as long as you are using water. Now when in the shower and the pump kicks on the pressure will slightly build. So the pressure will increase and decrease every couple seconds while showering.
I take this as normal but I have been told the pump should be running longer and then sitting idle longer. Am I wrong here?
