Is there anyway you could re-route your drain pipe to go into a downspout drain instead of going directly into the storm sewer
that must fill up when raining hard.
It would be hard, it's all underground from my basement wall to the sewer.
If this street flooding becomes a habit, I would intercept the line just outside your basement wall and install a standpipe that I would pump into.It would be hard, it's all underground from my basement wall to the sewer.
Are you sure you need a bigger pump?I am returning the Ridgid, getting a switchless Zoeller N267 with hydrocheck hc6000 which should be a stronger pump (7680 gph vs 5640 gph at 5 feet) even though it has half the hp but the same running amps. It has a 2" discharge pipe (vs. 1.5" now) which should help, and I will keep it 2" all the way to the 4" pipe in the wall. I will get rid of the current Y and with 3 checks and just insert 1 check valve above water level. I will Y in the current 12v back up pump and consider things from there.
7680 gph/128gpm. That basin is probably 25 gallons. If it completely filled five times a minute that pump would handle it. It doesn't look like it's filling up that fast.
Your Ridgid is only pumping out 5" of water (due to the float) plus some of it is squirting back into the basin.
You should try to find out how much water you actually have coming in and go from there. Turn the pump off and see how long it takes to fill up?
The N267 looks like a big pump. Your pit looks like it's very crowded now.
With the controller you can set the upper sensor up higher so the water will partially fill the drain tubes. That way it will run longer and not short cycle.
