I have a Grundfos pump (link below) installed right next to my water heater. I am fairly sure it was a retrofit pump but I am not 100% positive about that. I connected it to a zwave outlet which integrates with my home automation stuff, so basically the pump always stays in "on" mode and the outlet it is plugged into turns on either at certain times or when we hit a button (I'm just including this in case the power cycling is likely to have caused some damage).
The pump is about 4 years old. Everything had been working fine, but the last couple days I've noticed hot water is instantly available even when the pump hasn't run for hours and it would normally take a couple minutes to get to the hot water. At first I was worried there was a leak somewhere in the house, but I've searched all over multiple times for any signs and can't find anything wrong.
My new theory is that the pump isn't closing correctly when powered off, which allows water to kind of passively flow throughout the house so hot water is always available. I believe this is true because:
I'm not a plumber and don't really know anything about pumps, but my main questions are:
Link to specific pump: http://www.amazon.com/dp/B000JGA0S2/?tag=skimlinks_replacement-20
Edit to include better link: https://us.grundfos.com/products/find-product/comfort-pumps-up-10.html
Edit #2: Best link I've found with the most information: http://www.pexuniverse.com/grundfos-up15-10b5-tlc-circulator-pump-59896215
- The pump was hot even after being unplugged for hours
- The mystical instant hot water goes away if I close the valves on either side of the pump
- The pump is kind of at a low point in the house. I don't know where the guy that installed it pulled the "input" from, but there could certainly be a kind of slow downward flow that allows this to happen.
- Is this what likely happened, or does it seem crazy?
- Is there anything I can do to try and "fix" it (e.g. clean out some gunk inside the pump or something).
- If I end up replacing the pump, can anyone suggest a better option? All I need is a durable, VERY low power/flow pump with no frills at all (no timer, no sensing etc). This pump is like $300 to replace and seems excessive.
