With many small uses of water during the day the small tank can cause many cycles. But it is never more than the 100-300 cycles per day the motor manufacturers rate the motors to handle. (1HP and smaller 300, 1.5HP to 3HP 100 times per day) There are also many different ways to use water, even when just washing hands. Nobody washes their hands more than I do. I am a dirty boy, work hard, and wash my hands probably 100 times a day, sometimes with solvents as well. Lol. I have tested that when I leave the tap wide open during the hand washing, that I use 2-3 gallons for each wash at 1.5 GPM. But if I just trickle water to lather up, and turn off the faucet until needing to rinse, I can wash my hands 7-8 times with 1 gallon of water. Same thing applies when brushing my teeth.
I also have a open loop heat pump. I purposely undersized the HVAC so it would not cycle. I have seem many HVAC systems that are oversized and therefore cycle on for only a few minutes each time. If the heat pump is cycling, the well pump will have to cycle, regardless of the size of tank. If the heat pump only uses 20-30 gallons per cycle, an 80 gallon pressure tank (20 gallon draw) will cause the pump to cycle once per heat pump cycle. Even with a small pressure tank (1 gallon draw) the CSV would also cause the pump to cycle only once per heat pump cycle. The difference is the pump with the 80 gallon tank system would run about 2 minutes at full amp load to refill the tank during a 5 minute heat pump run. The pump with the CSV and small tank would run the entire 5 minutes the heat pump is on, but at about 50%-60% of full amp load.
You would think it best for the well pump to run only 2 minutes at full load amps and then shut off compared to running for 5 minutes. But that is not the case. The pump without the CSV runs at full amp load (max heat) for two quick minutes and then shuts off. It takes at least 1 minute for the motor heat that was created during pump start to dissipate into the water. That is why motor manufactures require a minimum of 1 minute of run time. But the motor stops while it is still hot, after running at full load amps for a minute or two. That is why motor manufacturers require at least 1 minute of off time, to let the motor cool before restarting. Motor manufacturers say 1 minute on and off is mandatory, 2 minutes is better, and running continuously is best.
It is much better for the motor to run for a longer period of time at reduced amperage. With a CSV the pump will run for the entire time the heat pump is running, plus one more minute to fill the tank. But depending on how much water is being used, the CSV will cause the motor amps to drop from 10% to 50% of max load. Amps reduced as little as 10% de-rate the motor load, making it run cooler. The more the amps are reduced by the CSV, the less heat the motor produces. The last minute needed for the CSV to fill the tank is at 1 GPM flow and the lowest amps possible for the particular pump. At such low amps, the motor is not hot when it shuts off. Therefore it also doesn't really need at least a minute to cool down before restarting. Although, restarting within a few minutes would be rare even with the small tank, as the 1 minute time delay off by the CSV made sure you were finished using water before the pump shut off.
Then, there is no reason why you can't use a CSV WITH the large 80 gallon tank, which gives you the best of both worlds. Any demand over 20 gallons is supplied without cycling the pump again. The CSV still gives the 1 minute (low amperage) motor cool down before the pump shuts off. There is another advantage of the CSV as the pump shuts off while filling the tank at a rate of 1 GPM instead of 10-20 GOM depending on the size of the pump. Shutting the pump off while pumping only 1 GPM eliminates the water hammer and damage done when the pump shuts off at full pump flow. At 10-20 GPM the check valve is wide open when the pump shuts off and the reverse of flow and slamming check valve will cause water hammer than shortens the life of many parts in the pump system. When the CSV is filling the tank at 1 GPM the check valve is only open a millimeter. There is no water hammer on pump stop, which makes check valves and many other things last much longer. Plus, with 20 gallons of water from an 80 gallon tank, the wife can wash hands as many times and any way she wants. However, over 30 years there have been many people in the same situation who ended up swapping out the large tank for the smaller one. They said they didn't notice much if any difference in how the well pump was working because of the CSV., which makes the large tank just a waste of money and space.
I appreciate the questions as I learn this stuff from my customers. They notice things like I mentioned above and ask how the CSV makes that happen. Then I have had to figure out how and why it works so well.
