Mellsworth
Hello all, new here and need help! Pex clamps on our hot water lines keep busting in our kitchen ceiling and I don’t know what to do!
Our home is 2 stories with finished basement, only 5 years old. The past 2 years we have had 4 water leaks in our kitchen ceiling, all from pex clamp failures on the hot water lines. Each failure is at a different site right in the middle of our kitchen and there is evidence of corrosion at the sites. The kitchen is kept at 70 degrees all year long. Our original plumber covered the pex in insulation. I have used 5 plumbers to try to find out the cause and no one knows. Theories range from water pressure, water temp being too hot, improper installation, bad batch of clamps, the pex being insulated, or our recirculating pump making the fittings too hot and corroding them have been proposed. I don’t think it’s an installation issue bc it’s only Happening at the lines in the kitchen which is weird but I’m not sure.
We have no idea what to do and how to stop these leaks!
We have a pressure regulator at the water main entrance so that’s not the issue.
