P Trap too close to drain
Nj078
Jan 15, 2022
Baltimore
Hi all,
I'm trying to install an autofilling and draining dog water bowl. The directions were simple enough and came with all the associated plumbing parts, however, where I intend to install it may or may not be a challenge. When I opened up the wall I had no room between the p trap and drain to put a tailpipe in (see attached photo). I'm wondering if there's a way that I can connect the two without a a tailpipe or perhaps the tiniest tailpipe? The only other option would be to move it to the other side of the stud and drill a hole through to give enough room, however that configuration is less than ideal for the dogs. View attachment 20220114_203334.jpg
I could probably raise it an inch, maybe 2 before it starts competing with the sink.
You can’t just run the drain outside ? I guess it might freeze up north.....
You’ll need to cut a tee into that pvc pipe and install a ptrap. You’ll need to make room fir that to be accomplished or it’ll never work.
Uploading a video for detail. Can't run the drain outside, too cold.
  • Untitled.mp4
    5.1 MB
