Overflowing outside drain clog - please help
davidmclean20
Mar 22, 2020
Springfield
Hi guys,
Just noticed my outside drain (side of house) is overflowing. Looks like wet toilet paper on the grass and the drain cover has popped off. See pic below. Any tips on how to fix this? It's not a constant flow.
Cheers,
Dave.
    1.8 MB
Main is clogged somewhere, do you have a housetrap? If you do see if the water level is higher then normal then snak/rod/plunger from there. If the water level is normal then work it toward the house given that drain is close by.... where’s that drain located in the picture?
