Hi all. I tried to remove the cold water stem from a faucet in order to replace the gasket. As I was attempting this, it cracked and then eventually about 1/3 of the nut broke off.
Threads are exposed and the nut is loose when turning the nut itself. Thus far with the main valve on there is no water leaking from it. When I open the hot water valve, a little bit of water comes out of the nut portion on the cold valve but then stops.
#1. Is this a part I can replace? I don't care whether it matches the hot water turn knob.
#2. Should I be weary of water pressure popping the cold water stem out? I'm not sure of the workings underneath as I stopped messing with it as soon as it cracked. I'm not sure if there is something besides the nut securing it down or if it's thus far stayed in place only because of many years of sediment and such binding it together.
Photo attached. Thanks for any help.
