Odd Faucet Shut Off Valve
theadamk
Aug 1, 2017
So here's a picture of my shut off valves that were under my vanity. I can't find these anywhere. Seeing if anyone could guide me on what I'm looking at. If you can't see it, the shut off valve actually has a hose stemming from it in one piece so the hose isn't separate. This is the first time I've seen this, and 3 of my sinks have this.
Those are the cheap angle stop/supply line combo. You will need to replace the entire valve and then purchase a new supply line.
  • Like
Reactions: SHR
You're going to want a 5/8 compression stop valve with a 3/8" comp outlet.
Don't cheat and try to install the new valve with the old nut and ferrule.
You will need to pull off the old nut and ferrule. They can be very stubborn.
