Helpmewithplumbing
I want to move our toilet by essentially rotating it 90 degrees. I need to move the flange slightly so that it is 12 inches from wall and has at least
15 inches of clearance on each side. What is the best method to do this so that drain and vent system are proper?
The current drain goes back a foot into the wall where it hits its vent and then the drain 180s back toward the front of the toilet toward the main stack tying in with laundry and shower. I will include pictures of the current set up shortly.
