My tub directions call for a tail piece and waste pipe stub to connect to my tub no hub cast iron. What should I be looking for at the plumbing store?
How are you going to access the cleanout if you need it?
If you use a cleanout tee instead of a tapped santee and turn it toward the wall. then you cover it with a chrome cleanout cover like the one Frodo mention earlier. I would use a plastic plug though. Those brass ones can be a real ***** to get out when you need to use it.
