csats
Hello,
Yesterday our hot water stopped working. I think I've been able to trace it to the circulator pump but not 100% sure. So no hot water coming out of the holding tank. Pipe is ice cold. All pipes coming into and out of tank are cold. Follow pipe from tank to circulator and boiler and it is cold until you get close to circulator. Above circulator it is just warm. I can hold the pipe. At circulator it is very hot to touch and below is very hot to touch. Other 2 circulators for heat are very hot and have very hot water coming out of them. I shut off the both heat and just had hot water circulator going. Could hear the motor going and occasionally heard a clicking sound. Thinking this means the fan inside or pump itself is bad. Hot water tank is calling for hot water. And the light on the boiler is on indicating it is calling for hot water. Could this be a bad circulator pump?
