new trap check
wkilc
Mar 15, 2025
Rhode Island
New counter, new sink. I cut out the old, glued-PVC trap and decided to go with a easily-removed threaded trap assembly.
New sink is slightly off center to connect the trap directly on the stub out line. Tried a 90-degree elbow and it all lines up perfectly.
Dry-fit photo attached. Is this okay? It's a standard elbow, not a long sweep. The latter would not allow for the alignment I have now. Is the trap-arm length adequate? I am assuming the arm length includes the bend.
There's an atmospheric vent in the wall, so that's why no cheater vent.
Thank you.
    210.3 KB
No ,you would want a couple of 45° to make the direction changes,
Thanks. Wouldn't a long sweep 90 be the same as two 45s? Problem is I would now have to finagle the trap to align with the tailpiece.
Also, since the pipe is smaller than 2 inches, wouldn't any quarter turn elbow be okay, even horizontal to horizontal? Or allowed, at least?
Again, thank you.
If you start at the wall with a couple of fittings.. And swing the trap to meet the angle it will work better and no not long sweeps in this case 45°,22 1/2, no 90°s
