Dennis Schaub
- Joined
- Jun 22, 2023
- Messages
- 1
- Reaction score
- 0
Recently purchased a home in Ohio built in 1977. Home was left empty for several years, so all plumbing and fixtures have been removed with the exception of the pressure tank which seems semi-new. I have a garden hose attached to pressure tank. The well has a submersible pump. The well has a line that T's off between the house and barn. The previous owner said he replaced the submersible pump 3 years ago. There is a 6-12" depression around the well head. I put 3 gallons of bleach and gallon of vinegar down the well head and then cycled the water through via the garden hose. To my surprise, the well head seemed to fill up with water after 10-15 minutes. I am not sure on the well depth, wells in the area average 100'. My current concern is losing water pressure. The garden hose will run at approx 7GPM for 15 minutes, but then rapidly lose pressure. Does this seem like a well issue, water line issue or pressure tank issue? It happens at both the barn and house, so I believe that rules out the pressure tank. Any help is greatly appreciated!
Thank You
Thank You
