Mitchell, thanks. A few things to note:
1. We have this kind of pressure tank...
https://www.flexconind.com/products/well-tanks/wellrite-well-tanks/
and I don't think the two black knobs on top are pressure adjustments. They look more like rubber stoppers to me.
You likely have a pressure switch on your system which controls the ON/OFF operation of the pump. Most well pump packages have a fixed 20PSI swing from on to off, but many can be adjusted so they can swing 40-60, 50-70, 60-80, 30-50, etc. Unless limited by pump/well limits.
2. We had shower and bathroom sink faucets installed in 2017, so they must be low-flow units, too. Since they feel powerful enough, I'm hoping a kitchen faucet would be similar.
Based on the International Plumbing Code the following are the flow limits for various fixtures.
3. Is a licensed plumber allowed to pull out the flow restrictor in a faucet?
I would think, providing it didn't exceed the limits dictated by the code. Then one may ask what if the home has a lower pressure resulting in a lower flow, which is the real concern.
Do you plan on having a licensed plumber do it?
As mentioned above, just find an aerator that meets the requirements of the code, which is a flow higher than 1.8 GPM.(Unless maybe in California ????)
