Ayer
Hello, I have a question about the toilet setup, and another question about the flooring around it.
The toilet had leaked water around it, so we took up the toilet and scraped off the wax on the bottom.
First Question:
First problem: not level. When we took up, the toilet, we noticed there were five or six washers at the rear side, under the toilet, which we figured the previous installer had put down to help the toilet not to wiggle as maybe the concrete floor is not level.
Next problem: pipe opening smaller than standard. The new wax ring had a funnel, but we couldn't put it in, as the funnel portion was too big for the pipe opening. The pipe opening is about 2-3/8 inch diameter, while the bottom of the funnel has a 2-6/8 inch outside diameter.
We went ahead and got a plain wax ring, put the washers back under the toilet, and set the toilet back in place on top of the wax ring. We wiggled and jiggled it to set it in place, and kept tightening the bolts, as it kept having a small wiggle. Then we filled the toilet tank with water and flushed a few times to see if it would leak, sure enough, water came out the front side again. We took toilet back up and set it aside.
Is there such a thing as a wax toilet ring with a 2-1/2 inch funnel, to be used with a toilet flange that was either replaced or set on top of the old one, but it was fit inside the 3 inch pipe and has narrowed the pipe to about 2-1/2 inch pipe opening. Is this the right approach or is there a better way? Should we use actual plastic shims rather than the washers the plumbers had used? Is it normal for the PVC flange to be slightly giving when we push down on it?
Second Question - Flooring:
This same toilet that finally leaked this week, has had a slight orange-pink colored stains develop on the vinyl flooring around it for the past several years. Research shows it could be some sort of bacteria or mold caused staining due to moisture. In the last few days just before the leak, the seam between two pieces of the vinyl had developed a dark color that had not been there. There must have been water seepage from the toilet base over the last few years that recently got much worse. Is it possible for the moisture between the concrete and sheet vinyl to dry up on its own? How important is it and what would be the best way to dry or clean the floor area between a concrete and vinyl floor, before replacing the wax ring and the toilet?
Thanks so much for any help and suggestions!
First Question:
