Dutch Stiphout
I am tapping into my toilet's water supply line to provide water to a bidet toilet-seat.
The 1/2 in. fittings supplied with the bidet would work on the fittings inside my toilet... but I can't reach them. The toilet is installed too close to the wall.
But the valve at the wall is accessible. There is a metal braided line connecting the toilet to the valve assembly coming out of the wall.
Here's what I'm *trying* to do... though I'm open to a better solution:
I turned off the valve, unscrewed the braided toilet supply line, and measured the fitting with a template... I thought it was a 1/4" line, so I bought tee depicted above, and... the 1/4 in. (female) part of the tee wouldn't screw onto the wall supply valve's fitting. Ugh...
The braided hose from the toilet could (almost/barely) fit onto the 1/4 in. (male) part of the tee... but I think I've just got the wrong tee... is the wall supply fitting not NPT? If not... what is it?
See pics... might help explain.
Anyway, can someone provide some advice? Is there an easier/better way to do this?
IMG_2807
comparison of the 1/4 in. male side of the NPT tee I bought and the supply valve's male fitting.
