Need help identifying bathtub faucet
Look for set-screws behind each handle (look for a small hole with a hex-recess in it) and unscrew each a little. If none there, look for a way to carefully pry off cover in front of each knob; in this case you will probably find a phillips head screw - remove. Hope this helps
