steve80
Hi,
Lately I've had the following issue. when 1 hot faucet is open, no problem, but when I open a 2nd hot faucet, both faucets drop in pressure, then after about 5 seconds, it gets to normal hot pressure.
I've descaled it 3 times in 2022 (we have soft water) and the water coming out was not dirty at all. I clean the water/air intake filter, etc... all the usual maintenance stuff.
I replaced the Check Valve as it had a broken gasket and caused cold water mixing into the hot water (that was a different issue), the plumber replaced the Flow Sensor and Water Adjustment Valve.
Any thoughts as to what the issue could be?
I'm hesitant to get another plumber because I've already had 3 in (1 was the installer, 2 were other companies as I was hoping they'd be better than the installer).
Thank-you in advance!
