StandingWater
Hey Plumbers - I could use some help identifying what's going on with this drain.
Moved into a new place and the cats managed to pull up the floor drain cover since it wasn't screwed down and they'll mess with anything that isn't screwed down. This drain's in the basement floor near the washing machine and it's set into the concrete slab, but the concrete's been busted up all around one side and refilled with loose gravel. The image explains it better than I could:
Underneath the drain cover we have this (warning: probable poo):
So the 6" round the drain cover sits over is mostly rusted out and covered in dirt/s--t/idk (It doesn't smell). There's an 1.5" pipe in the middle of it all with standing water, whose "lip" is higher than the "base." I tried flushing the middle pipe with a little water, assuming it was the exposed end of a trap, but it just ended up overflowing and draining out through a hole I hadn't noticed at first in the right side of the drain.
I'm guessing that hole-in-the-side is the cleanout that just isn't plugged? But what's up with the "middle" pipe with the standing water - maybe it's just totally clogged with loose gravel? And why would the actual drain in the middle of this whole contraption be "elevated" about 1/2" above the "floor," allowing water to overflow and pool around it?
I kinda want to just ignore it and get the cover secured, but now I'm paranoid.
Any help identifying what's going on would be very appreciated
