Hello,
We have had a mysterious problem for the last two months at our house. There has been a persistent flow of some sort of sediment that is clogging everything on the hot water side.
Our setup:
City water --> softener --> tankless heater
We also have a recirculation loop with a small 6 gallon tank heater that runs continuously with a small pump.
Our house was built in 2006 and the softener wasn't installed despite hard city water until 2015. The heater was a Rinnai R85.
I've attached some photos of the gunk that continues to be caught in the showerhead screens and in the screens in the valves of the Grohe fixtures.
The progression of problems has been this:
-initially recirculation loop stopped working.
-plumber looked at it and thought check valve was not working so replaces that
-still didn't work and plumber determined 6gallon heater not working
-replaced 6 gallon heater
-during this time noted that there was resin in toilet tanks and determined that softener membrane was bad and resin was escaping.
-softener to bypass mode
-no resin found in screens around house
-softener rebedded
-hot water flow worsened.
-part replaced in tankless heater
-flow and pressure in showers still low
-gunk / sediment continuously filling up screens and slowing flow. Flow great once cleaned then after about 20 showers it worsens again to a trickle.
I've checked the pressure from the city - 110psi
Pressure after pressure reducing valve and just after tankless is 70psi which is the same at the shower heads themselves.
We initially thought this could be from scale built up over a decade of not having a softener in the old tankless heater.
We ended up replacing the tankless with a Rinnai RE199IN thinking this may fix the problem.
The new heater works great but the problem persists.
After ten showers or so the flow slowly starts to decline to a trickle. Then when we look at the screens it's full of this stuff and clogged. We remove the sediment and the process starts over.
We've worked with some great, experienced plumbers but so far two of them are stumped.
Does anyone have any idea what this might be coming from and how to get rid of it?
It is gray/green color and not necessarily hard like I would expect calcium scale to be.
Thanks for any help!
Our setup:
-softener rebedded
