I discovered that there is some slightly exposed tape but it is on pretty securely. However, I will be mindful to avoid applying adhesive over those spots when I install the surround. The instructions say to caulk around the holes and I was trying to figure out how to get that done without dry fitting the surround, drilling the holes, and hoping it lines up when adhesive is on. Then I decided what I will do is put the adhesive on the surround as instructed, but put the adhesive caulk stuff around where I marked for holes to be drilled. I'll give it some extra space so it's not tight around and drilling through will not cause it to hid any adhesive. I've already put foam board on toothpicks over the spot for the controls. Shouldn't be too hard to mark the area for the tub spout as well. Once the walls are secured & the adhesive is cured, I will drill holes. First pilot holes from the closet side and then the full size holes from surround side. I will probably put tape around the cutting area.
Found some more filters for my shop vac so will get that changed out & vacuum up before installation. Really need to do some major cleaning in there. Will have water, sponges, and shop towels on hand in case any adhesive falls off somehow.
Meanwhile, I need to touch up and re-do the repair stuff. I should test the different colors available and see which one matches the tub the best as the on I chose (enameled steel) was too bright. However, when sitting on the toilet it is hard to see the messup and its not visible from across the room. Looks like spilled paint up close. Dremel tool should help. I found that the stuff doesn't solidify/dry without using the blue light. I'm going to try to spread it with a brush this time and feather the edges before I put try to cure it with the blue light.
As a reminder, this is before:
This is after:
Once I clean it up I'll try to take pics from a more similar angle to the first pic. Although, I had a different camera for that as well.
This is after:
