Soquilii
I have a 20-year-old mobile home and just now discovered a hiss in the laundry room emanating from behind the washer. It sounds exactly like air, not water! There is no water on the floor and I don't feel water coming through the pipes to or from the washer. When I turned the washer on, it worked. I cut off the water using the inside valve (stopcock?) and the hissing stops. I'm going to leave it off all night.
I will have to move the washer away from the wall tomorrow and unscrew the panel behind it to see if there is a leak; meanwhile I will keep the water cut off.
Does the hissing mean there is a leak?
We live in the woods; could a rat or raccoon have chewed through a pipe?
Has anyone else with a mobile home experienced this? What did you do?
I'm open to suggestions! This is the first time this has happened.
(I am a 71-year-old widow with no one to fix it and very little money to hire a plumber! Any information you can give me will be greatly appreciated! I will probably have to jury-rig a solution.)
