brassmookie
Active Member
Recently bought an old house with old drain pipes. I'm in the process of figuring out how to replace the metal pipes with PVC. A couple of questions. For one, the original system includes a p-trap on on the mainline. I had a plumber come in at some point that mentioned that was probably no longer required by code (I'm in NY). Whether or not it is required by code, it is still best practice to have a trap off the mainline, or is that unnecessarily redundant since every outlet off of the mainline will have its own trap? Secondly, there are a couple of large elbows that have a left and right inlet into the elbow. I haven't been able to find the PVC equivalent of that particular piece. Would I be able to use something like this, and simply cap off the extra hub?
