No, pretty much the same. At times it gets hotter but mostly just warm. I got distracted with another project so haven't messed with it.
To answer some of the questions.
No way I can check hot water flow with guts out. How would you do that?
I have a stand alone hot water tank. Brand new set to 150. I know that's hot but figured I least get warm water to tub.
I have a single handle valve either a tub/ shower diverter.
Haven't called symmons yet but soon.
[/QUOTE
Was there any resolution to this? I have an older Safetymix shower with luke warm water also. Used to work fine. Hot water tank. Replaced the Symmons mixing valve with two different C-5 valves (several holes) and no change. They all click and move freely. Adjusted hot screw already. Read somewhere to replace hot/cold seats also but not sure how that would help? Could it be a pressure imbalance? The water gets hotter when I reduce the flow directly on the showerhead. If so how can I check that and or fix? Thanks.
Have you adjusted the volume control knob above the valve body your valve only has one large seat those seats almost never fail
