Brandon T
I would appreciate any ideas from the forum.
We recently purchased an older home and the house has excellent water pressure, however the shower is a trickle. It has a Delta 1400 fixture. I replaced the cartridge, but that did not help. The original cartridge and the valve body both looked very clean. When I opened the main (partially) without the cartridge in place, the water flow was very high.
Inspecting the pressure balance valve body, it looks like a diverter(?) is occluding the flow. There is no diverter assembly below the valve body. What do I do? Does anyone have any ideas? I feel like it shouldn't be there or that there should be access to a lever.
Thanks in advance for your help!
Brandon
Brandon
