vanbands
I recently purchased my first home. There are 3 outdoor spigots on the house. 1 on the front of the house, 1 by the garage, and 1 on the deck. The spigots by the garage and on the deck were service by a local plumbing company April 2021. They installed a shut-off valve for each spigot. One shut-off is labeled "Garage and Deck" and is located in the utility room where the water heater is. The other is labeled "Deck" and is located in the garage. The problem I am experiencing is when I turn on either spigot, the initial pressure is normal and quite strong, but after a few seconds, the pressure reduces to a slow trickle. There seems to be a correlation between the amount of time the spigot is closed and the amount of time the pressure is normal. If I leave either spigot shut for about 10 minutes or more, the pressure is normal for almost 10 seconds before slowing to a trickle. The spigot on the front of the house was not serviced by the plumbing company and functions normal. It also appears to be the oldest one. Both of the shut-off valves installed by the plumbing company are fully open and all water fixtures in the house function normal and with good pressure. The spigots are typical I need help diagnosing the cause of the problem as well as formulating a plan to fix it.
