I had to remove the trap on my bathroom sink, and now I cannot it get it to not leak. The trap and nuts are metal, while the waste arm is some kind of black plastic. Rather than using a washer, the trap arm has a beveled or tapered end that interfaces directly with the trap. I went ahead and bought an identical replacement metal trap, because the old one was in bad shape. Upon reassembly, I have leakage from the connection between the waste arm and the trap. I have tried tightening to different degrees, disassembling and reassembling several times, and still I have a leak.
The beveled end of the waste arm is slightly scored from previous compression, but it does not appear to be badly damaged. Obviously, if it was a washer I would replace it, but it doesn't look like the waste arm can be replaced without removing the whole vanity.
Am I missing something? Is this a job for teflon tape? Putty? Is there some kind of gasket I can add to the beveled end of the waste arm?
Thanks in advance!
Bryan
Thanks in advance!
Bryan
