Is the chrome tailpiece ovaled. that 1 1/4" washer should fit tight on that tailpiece. Also, check that it isn't leaking from higher up and pooling around that nut. I have seen many pop-ups leak at the bottom of the sink connection.
If this is a brand new faucet I would go to faucet barn and show them what broke and let them replace it for you. On your leaky drain can you show a picture so we can see the gasket on the pipe like Blair mentioned.
Only thing I haven't seen, are you putting the rubber washer on correctly. Should seal. Am a service plumber. Seen it numerous times where the washer is upside down and the home owner doesn't know why it continues to leak. Also, don't glue anything there unless it's a last resort. If you ever need to have the drain cleared it could be a real pain.
