Hi everyone,
The sink in my kitchen won't drain.
This is a new condo unit, it's been only 8 months. I'm not a pro, but I lived in apartments for more than 10 years and never had this issue.
My first attempt was to use a chemical. That didn't work.
Then I tried a plunger and snake, also didn't work. I noticed that the snake wouldn't go further than 4 or 5 feet. So I decided to take that U shaped pipe (sorry for the terms, I'm not familiar with the terms). The U pipe was clean, so I decided to try snaking from there, where I removed the U pipe. I noticed it wouldn't go more than 2 feet inside, right where there's a joint.
So I opened the joint and I noticed there's a tube inside, almost as large as the pipe. I'm not sure if that's okay o not, but I noticed that the joint was causing the blockage because of this tube inside. (picture attached).
Because of the tube, I can't snake it any further.
Is that normal to have a tube inside the joint? Also, any idea of what I can do to try fixing this issue?
PS: I picked as much dirty as possible from the joint, but it still not working.
Thank you.
Thank you.
