dolfans
Active Member
The kitchen sink pipe is leaking and going to the basement. I have messed with it today (6/10/11) The pipe that is in the wall straight across had a hole in it (metal) and clogged. I am going to get some parts and fix it myself i help. The pipe connector is with the pipe going to the roof. Should i replace everything from the connector down or just the part that had a hole. I already cut it out. The pipe that i may replace is not that long alltogether 4 ft i say. If i replace that pipe (metal) can i use pvc and a rubber boot(sleave) above the connector? What size is the pipes 1 1/2 and 2 inches? The house was built in the mid 60's and that has not been replaced that i know of. Thanks
