Is Sharkbite brand PEX B reliable?
wtalber
Dec 25, 2024
14
USA
I am planning a small job for our house, and do not want to buy a 25 foot roll of PEX. Sharkbite brand PEX comes in shorter lengths, and is available at Lowes locally. As far as I know, it is made in US. Opinions? Thanks.
I’d use it for a small project if that’s all I wanted to pay for.
I use Rehau pex.
SharkBite PEX B is a convenient option for small projects, especially if you only need a short length instead of a full roll. It meets industry standards and is widely used in residential plumbing. While it’s more rigid than other types of PEX, it’s still easy to work with as long as the connections are properly installed. SharkBite’s PEX is made in the U.S., which is a plus in terms of quality control. If you’re using their push fittings, just make sure the pipe is cut cleanly and fully inserted to avoid leaks. It’s a solid choice for quick repairs and smaller jobs.
Thanks for the reply! From other posts, I have gathered that I wanted pipe made in the US, for your reason. I have all my parts, and just have to start this project. I went with Boshart stainless steel elbows and a tee. I also ordered some decent PB to PEX adapters. I plan to use my newly acquired Ridgid ring crimper on those adapters, and the Oetiker tool on the Oetiker clamps in the rest of the project. I will have some extra PEX for an emergency. I appreciate your input.
I would use Rehau pex and not use the stainless steel cinch clamps.
I’d use copper crimp rings.
I’d never choose sharkbite pex for an entire project, only rental dump repairs.
Great! Sounds like I'm going to create a disaster.
I’ve been crimping pex since the early 90’s. 20 years ago I started using Rehau pex and haven’t looked back.
The Boshart stainless fittings are nice. I’ve been using them for a few years since they first came out.
I need this to last until we replace all the Poly B, which has lasted 30 years, with one pinhole leak early this year. I like to be able to buy a five foot length, not a 25 foot roll. I looked at the Boshart fittings, they seem like good quality.
Then I’d use whatever pex I could find. No big deal. No way I’d pipe my whole house with sharkbite pex
Thanks. I'm replacing a 30 year old PRV. Local plumbers are charging $400 or more just to delete them. I don't want to destroy anything, just get back some volume and retain ~50PSI. If I were doing the whole house, I'd go with the popular brands mentioned here, and check out Rehau. I'd buy rolls then.
Better check with your insurance company. Many will NOT knowingly insure a residential dwelling plumbed with polybutylene pipes. Thus, your insurance could be null and void, and if you have a mortgage, you may be in violation with the lender too, if your insurance is void, whether you know it or not.
The insurance company isn’t picking on this. PB was banned years ago, lots of legal action, blah blah blah. They also generally won’t insure a home with other folly offered by builders to save a few cents over the years, and some of which remains and has a statistical record of being dangerous. Federal Pacific Stab-Loc or Zinsco service panels, Inselbric siding, aluminum wiring to name a few.
Thanks. We filed a claim early last year when we had the pinhole leak. Nationwide paid out, and the adjuster told them it was Poly B. I have copper wiring, thankfully.
Many insurance companies will not write insurance against water damage from the poly B.
If they do write insurance to cover Poly B it often states that they’ll only pay one claim caused by Poly B leaks.
If your insurance covers PolyB you must be paying through the nose.
