We had a contractor do our shower recently, and after several issues we're questionining more and more all the things where "this this is fine don't worry about it" essentially. One of these things is on the shower drain. The drain needed to be moved over about 1.5 ft or so. To do that, some concreat needed to be knocked out to get access to the pipe, which makes sense, but then when everything was being connected up there was some rubber flex pipe used in the P trap section. I'm not sure if it was a 90 degree section or if it was a larger curve (i've attached an example image of generally what i remembered it looking like) , but either way, this black rubber type of material was used to connect the PCV pipe in the P trap.
Is that okay to use? I feel like it's not ideal for sure, but i'm not sure if it's actually going to be a problem or not. Thanks for any advice
