Cottage House Owner
Hello Plumbers,
See Photos of tub drain pipes going up and down...will I have any issues with water in tub exiting fast?
Also, the plastic blue waterline was nicked during the sawing of the drywall to open the ceiling to move this drain to the correct location for the tub, will this be an issue later, or is this tube thick and it is not an issue? It is not leaking yet, just a scratch from the saw in the blue water line.
I am a homeowner and we hired plumbers to install a footed tub and all new plumbing pipes.
When the plumber went to hook the tub to the drain hole he noticed that the hole to the drain in the wrong location and he moved it 1 1/2 inches, which included sawing open the living room and moving pipes around to line up with the new hole. The new pipes go down and then up before connecting to main water drain, a few wild twists. My concern is will this tub drain correctly, and how will we clear out hair or clogs in the future. I need to know if this is going to work before closing our living room ceiling, or if these pipes need to be redone? Thank you, Cottage House Owner
