woodbkayaker
I have a nasty situation. I have a test cap glued into my 3" house drain line just outside the foundation wall, and wonder if anyone can suggest a way to remove it without digging out the line. For example, a roto-rooter style bit that would make a clean 3" circle cut. The attached diagram that illustrate the situation.
=== The back story:
I am building a retirement house in a location in rural Washington state. Plumbing is one of the trades I know the least about. So 5 years ago, when the foundation walls had been poured, but before I framed the house, I called upon a neighbor there for help hooking my house drain line up to my septic tanks. The neighbor is a retired plumber from the US Navy. His advice (he charged me $50 for an afternoon coaching me) was that when the time comes for inspection -- when the drain/waste/vent system needs to be filled with water -- testing is made much easier if you've glued a test cap into the drain line. It avoids the mess of using a test balloon. He said no problem to knock the test cap out later. He'd come out and show me how. After I had glued in the test cap, I got nervous how I would get the darn thing out, so I added a cleanout just upstream of it ... giving me some (limited) access. (see diagram)
Five years later now, I have passed all of the framing/electrical/plumbing rough-in inspections, and I'm ready to install interior plumbing fixtures. But there's still this test cap in my drain line. My neighbor just shrugs about getting it out and says "Aw, it's easy". His preposterous suggestion is just to reach down with pliers and pull it out. But of course there is no way to fit a hand with pliers into a 3" drain line. Is he remembering commercial jobs that had larger diameter lines? Or did he play a Navy practical joke on me? Too late I have learned that he's not a guy I should have trusted.
=== The back story:
