piikoiCoder
Short Question:
Where can I find the correct plastic pipe to mate with a 1/2" compression nut on a BrassCraft under sink water cut off valve?
And the little metal insert needed to safely use a compression fitting on plastic pipe … (I don’t know its name?)
It seemed an easy question that I should be able to answer for myself. But I guess it’s such a dumb thing to do no search turns up an answer.
Long Sad Story: (And why it’s not my fault. Some previous licensed, but I guess not professional, stuck me with it.)
The goal was to swap out a dripping under sink valve. The surprise was to find the valve was on the end of a plastic pipe whose other end now disappears into inaccessibility … I hadn’t noticed the contractor who modified the sink cabinet snuck plastic into our originally all-copper pluming.
Complication: Unfortunately the main1/4-Turn cut off valve has always continued to dribble
… not fast, but steadily when off.
Not enough for major repair yet, because it’s never been a problem when swapping out other under sink valves on that line, but …
The leaking valve’s 1/2” compression nut was screwed down on the plastic pipe without the little metal insert, which I discovered meant …
The compression ring gets sunk so deeply into the plastic it can not be removed (and in this case refused to be resealed) so …
With the main line still dribbling
… and no working under sink valve
… I had to cut the pipe to get a clean end which meant …
The new valve’s compression nut is now too far behind the back of the cabinet wall to get the two wrenches needed to compress it enough to seal without snapping the plastic, which meant ...
I had to do emergency surgery on the back cabinet wall, which …
Left me with another compression ring sunk into the now shorter plastic pipe without the little insert which meant …
To seal it without the insert, I had to crank it down so tight it again sunk
the new ring forever into the pipe which means ...
Means I need to eventually cut it off again and then glue an extension on to the old plastic pipe before I can
a) make a proper connection, and
b) repair my surgery on the back wall of the cabinet.
Help would be much appreciated.
Oh ... and no. I can't replace the plastic pipe entirely, because the other end is too far behind a new wall that I'd have to rip open again to get to it.
