I was removing the lead seal in the cast iron hub right above the concrete slab and the hub ending up breaking off entirely. Now I have the pipe slightly below the concrete slab (see pictures). How to I go about connecting to pvc with this now? I was thinking of removing the surrounding concrete to connect a compression fitting to the pipe, but I would ideally want to add the concrete back and I don’t know if you can do that with the rubber fitting there. Thoughts?
