I have recently moved from
an area where I had a well with a steel casing, 220' deep, with a 3/4 hp multi staged submersible pump about 20' off the bottom, connected to a pressure tank via a pit less adapter below frost and this pressure fed the home.
Now I have a well with a pvc casing with a square Franklin, pressure switch device, going to the home to a standard filter through a RO filter to a calcite 1cu ft tank with no timing valve to another square Franklin pressure device? to a 350 gallon plastic tank with an aerator and float switch, with another submersible pump to pressurize the home.
Is it normal not to have a pressure tank somewhere in this secondary side of the system so the pump in the tank does not start every time a faucet is opened?
Also the RO filter seems to backwash? randomly or does it function this way wasting water every time the float switch calls for water to fill the holding tank?
I am very confused why a new home was set up this way and do not like the constant change in water pressure to the fixtures.
It seems that it would have been less costly to use one pump in the well casing, use the holding tank as a pressure tank and use timed or metered valves on the backwash filters while aerating the water inline before the tank.
Is it the RO that I am not understanding that prevents it being set up, what I would call normal?
