I think those hot water bypass valves are for use when there is no pumped return line watts makes one with a very good description. I meant you could shut off the hot line out, then check for flow on the hot side
If you search hot water bypass valve you can see pictures of the valve and complete braided hose kitDarn I didn't understand.
What is not 3/8ths?
