sbell8100
Hi All! I live in a 3 story townhouse. The first story being ground level (above ground basement). My issue is that even though I have hot water in the tank available it won’t travel to the 2nd & 3rd floors automatically.
I have to go to the ground level & turn on the hot water tap in the laundry tub, let it run for a minute then I can go upstairs & will have hot water. The cold water flows no problem & the water pressure seems fine.
Do you think it’s the water tank itself? It’s Approx 14 years old & this has happened for at least 5 years or is there a vent Issue or something. It did work no problem for several years. I can’t find a lot of information for this issue. Help! TIA.
