Honeywell Braukman Pressure Regulator Valve
Bill T
Feb 26, 2021
5
Massachusetts
Hello
I have this DO5 regulator in my home and have for over 30 years. Whenever I flush a toilet or run the washing machine, the regulator chatters and the pipes vibrate. I have it set for 80 lbs. I've tried cleaning it to no avail. It apparently is so old that you can't but a repair kit. Any suggestions? If I have to replace it I can, but would rather go the simple route first. Thank you in advance.
I would replace it. Most residential pressure regulators aren't adjustable above 75psi. If you're getting 80+psi it has failed.
