Rural Montanan
I noticed a hole in the ground between my septic tank and my drain field that smelled. Sensing a problem with the sewer system, I excavated. Here is a picture after digging:
I removed dirt, some gravel and what looked like black sand. The outlet pipe on the right had become clogged with sand and dirt. I cleaned it out as far as I could reach my arm in.
How do I fix this? My rural neighbor suggested that the person who installed the drain field septic system failed to connect up the inlet to this box to the two outlets, and that I should buy some tubing to make the connection. But, I wondered what would be the purpose of the concrete box that appeared to have a bed of sand, and the gravel that was in the hole. On the other hand, obviously the drainage from the septic tank to this box eat away at the dirt to give the hole.
I wanted expert advice. So I googled "forum & sewer problems" and found this. I am hoping you can advise on the the way to fix this. If I can't do it myself, I can call a contractor, but knowing what the correct solution is versus relying on the contractor to tell me.
