Greetings! I hope everyone had or is having a great weekend. Feels like Spring finally here in Michigan.
I am looking for help with an installation issue I am having with the above mentioned municipal water supply powered back-up sump pump from Zoeller.
https://www.zoellerpumps.com/wp-content/themes/zoeller/content/literature/FM3170.pdf
I installed my first unit a month ago and had a leak between the unit itself and a 1" x 3/4" plastic bushing/reducer in the image and video below when I hooked up my water supply to the unit using the quick connector that they provide in the box.
View attachment My Movie.mp4
The first time I purchased a brass bushing to use in place of the plastic and also got a leak at that same join and between it and the quick connector Zoeller provides.
I called Zoeller, and their support asked me to ensure I fully tightened the bushing to the unit which I did and I still got the leak. They said I may have a cracked unit and quickly sent me out a brand new one which I just installed not reusing any parts and I have the same exact problem.
The install manual states:
INCOMING WATER PRESSURE:
40 PSI minimum with valve open.
80 PSI maximum with valve open.
100 PSI maximum with valve closed.
This is installed right at the entry point of my water supply. I measured my pressure with a $15 water pressure device from my hardware store at around 70psi after I removed the first unit and before I installed the second.
I will contact Zoeller support again but they didn't have any ideas the first time other than tightening the bushing as far as I could. It is possible I have two bad units or this bushing is rarely used and therefore problems with it are rarely reported. But the odds seem low that is the case.
It is a threaded plastic unit to threaded plastic bushing connection point and the manual did not state to use teflon in that connection so I didn't. Reading online in a few places, I learned you really shouldn't use teflon in a plastic to plastic threaded connection anyway.
Should I buy a pressure reducer for my 3/4" piping as an option?
Is there a water tight glue/sealer for these two plastic pieces I could use? I don't need to uninstall those two pieces ever again since I can remove the unit through the quick connector.
I am open to any suggestions/directions. I am fairly handy with house projects with the exception of soldering copper pipe and joints, thus my use of quick connectors (which aren't leaking at all) on this project.
Cheers and take care!
