newhomeownerreno
Hi there,
I recently bought an older home, and I am planning on having the basement floor repoured.
Before I do, I want to make sure the plumbing buried in the old concrete is good to go. There is a slop sink in the basement that I would like to keep there. It drains into an old cast iron pipe in the floor. About 2 feet behind the sink is a cast iron cleanout. I am sure it is connected to the sink, because when the sink drains, the water in the cleanout starts moving. There is a plug sitting next to the cleanout but it no longer fits on the old rusty pipe.
I am trying to figure out how these are connected/what the cleanout might be for. I am also trying to figure out if I should excavate and try to have it replaced before pouring the new floor, or just try to use PVC & some kind of coupling to lengthen the drain and the cleanout so they will stay over the top of the new concrete.
I also know that often when there are two cleanouts next to each other, they are part of a whole home trap. I know this is not the building trap as that exists elsewhere.
See my photos attached. Any thoughts? I have had several contractors through and no one seems to be able to tell me what I should do about this...
-Confused new homeowner
