geoffhazel
House is 40 years old. Frost-prooof hose valve is broken, won't totally shut off, needs to be replaced. There's a plastic piece on the end that's cracked. How it's laid out is like this:
So we have the incoming water line below, into an ell headed up to a 1" x 1/2" x 1" galvanized tee.about a foot higher, where the f/p valve comes into the 1/2" side. Out the top of the tee is a short 3" section into another ell that heads away to the house.
The frost proof valve is about 12" long, and appears to connect via female threads to the close fitting that is threaded into the tee.
What's got me puzzled about how to proceed is that the close fitting is super rusty. Rust ALL OVER, and some of it flaking off. I get the impression that if I was to mess with it to any degree it would just fall apart.
It appears that the frost proof valve is threaded onto it b/c I can see some teflon tape sticking out of the edge of the threads. The f/p valve has threads on the outside too.
I'm thinking I could try to unscrew the f/p valve, but if that little rusty part goes into dust, what am I gonna do then?
One thought I had was to cut the f/p valve and try to connect directly to the housing with a shorter one -- it LOOKS somewhat like 1/2" copper pipe -- but if the size isn't perfect, I can't sweat or use a shark-bite fitting on it.
I also thought about cutting the 1" line above and below the tee, trying to unthread the pipes above and below, and then put in new pipes with union(s) as needed to replace the tee and all other parts with new. Hopefully those other pipes will unscrew. They aren't the least bit rusty (on the outsides, anyway).
What would you recommend for a repair procedure?
